14 years agoConnecting Wishbone I2C to NIOS2 in Qsys
I've seen a few posts related to this subject but they are all pretty old. I'm using Qsys, and I want to connect a Wishbone I2C core to the NIOS2 processor. I'm confused as to how to do this.
I know the signals between Wishbone and Avalon are pretty similar - that's not the problem. The question is WHAT do I do in Qsys to hook the thing up??? Do I use some ready-made thing out of the library, like a Avalon MM pipeline bridge or something else, to hook it up? OR, do I do the 'New Component' thing? Surely somebody else has hooked the Wishbone I2C up to a NIOS2 processor before - is there some Qsys library component that somebody has that they can post? Thanks2 Replies
I did it several times, using the "New component" button, but I had to write a wrapper around the component to convert the Wishbone interface to Avalon. There isn't a lot to do IIRC, just something around the chip select and read/write signals.
I don't think QSys supports the Wishbone interface natively (yet?) - Altera_Forum
I've performed this before in both SOPC and Qsys. Daixiwen is correct that it
can be performed by creating a new component and attaching a wrapper hdl source file that links the Avalon signals to the Wishbone signals. SOPC/Qsys will analyze this file and generate the signals needed. An alternative method I use is to create a new component and link the core to the NiosII system in the top level hdl source. The new component definition does not include any source files. It has up to four interfaces defined for an Avalon MM-Slave, clock input, reset input, and interrupt sender. The Avalon MM-Slave interface should use addressAlignment NATIVE. Add signals for writedata, readdata, address, chipselect, write, and waitrequest_n to the Avalon MM-Slave interface. Add the clock, reset, and irq signals to their respective interfaces. Then add this new component to the system contents in SOPC/Qsys. The signals defined for this core will be added to the port I/O on the NisoII system module. The instantiation below is how I attached an I2C interface from OpenCores in the top level source. i2c_master_top# (.ARST_LVL(1'b0)) I2C_Master ( .wb_clk_i (clk_cpu), .wb_rst_i (1'b0), .arst_i (reset_n_to_the_I2C_Master), .wb_adr_i (address_to_the_I2C_Master), .wb_dat_i (writedata_to_the_I2C_Master), .wb_dat_o (readdata_from_the_I2C_Master), .wb_we_i (write_to_the_I2C_Master), .wb_stb_i (chipselect_to_the_I2C_Master), .wb_cyc_i (chipselect_to_the_I2C_Master), .wb_ack_o (waitrequest_n_from_the_I2C_Master), .wb_inta_o (irq_from_the_I2C_Master), .scl_pad_i (scl_pad_i), .scl_pad_o (scl_pad_o), .scl_padoen_o (scl_padoen_oe), .sda_pad_i (sda_pad_i), .sda_pad_o (sda_pad_o), .sda_padoen_o (sda_padoen_oe) );
