Mahdi
4 years agoconnecting Stratix 10 External Memory Interface (EMIF) to multiple AV-MM
I have a design with two AV-MM read ports and one write port, including read_data_valid and write_data_valid, and separate watirequest for each port. All these three ports are master ports,...
- 4 years ago
FYI, master = host, slave = agent.
In Platform Designer, you can connect an agent interface to any number of host interfaces. The arbitration logic is automatically implemented in the generated interconnect. That's one of the handy features of using PD. Just make the connections in the usual way in the tool (dots in the Connections column or right-click an interface to select what it should be connected to) and generate the system.
AdzimZM_Altera
4 years agoI’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
