connecting Stratix 10 External Memory Interface (EMIF) to multiple AV-MM
- 4 years ago
FYI, master = host, slave = agent.
In Platform Designer, you can connect an agent interface to any number of host interfaces. The arbitration logic is automatically implemented in the generated interconnect. That's one of the handy features of using PD. Just make the connections in the usual way in the tool (dots in the Connections column or right-click an interface to select what it should be connected to) and generate the system.
- Mahdi4 years ago
Thank you so much for your help!
