connecting Stratix 10 External Memory Interface (EMIF) to multiple AV-MM
- 4 years ago
FYI, master = host, slave = agent.
In Platform Designer, you can connect an agent interface to any number of host interfaces. The arbitration logic is automatically implemented in the generated interconnect. That's one of the handy features of using PD. Just make the connections in the usual way in the tool (dots in the Connections column or right-click an interface to select what it should be connected to) and generate the system.
Hi Mahdi,
Thank you for submitting your question in Intel Community.
I'm Adzim will assist you in this thread.
Based on your design configuration, I think you can create your own custom memory controller.
The DDR4 EMIF IP can be generated either Hard PHY only or Hard PHY and Hard Memory Controller.
If you want to use your own memory controller, the EMIF IP can be generated in Hard PHY only configuration.
Adzim
- Mahdi4 years ago
Thanks for your reply, but my question is whether I can connect three AV-MM Master ports to this AV-MM slave.
If not, how can I do this?
