16 years agoconfusion about scaler
hi, I have a problem with scaler, my data path is : CVI(clocked video input)->SCL(scaler)->FRM(frame buffer)->CVO(clocked video output) It takes the input resolution 800x600 and scaled to 1920...
16 years agoYou should probably check the following thread since this seems to be the system you are trying to implement:
http://www.alteraforum.com/forum/showthread.php?t=21066&page=1 It is mentioned that the CVI could have some issues with some DVI inputs. This could explain the flickering in your case.
