16 years agoconfusion about scaler
hi, I have a problem with scaler, my data path is : CVI(clocked video input)->SCL(scaler)->FRM(frame buffer)->CVO(clocked video output) It takes the input resolution 800x600 and scaled to 1920...
16 years agoHi,
If you use the Scaler as is (without controlling it via the run-time control) then the input is fixed per the configuration in the SOPC. If you use the run-time control then the input resolution is the maximum resolution you can input. BR, Reuven
