UMall1
2 years agoConfiguring a PLL
I am using a Cyclone iii device and I have an interface to an Imaging sensor that receives MIPI outputs. ONE CLOCK LINE ONE SYNCHRONIZATION LINE FOUR IMAGE LINES Cyclone III has a core speed limi...
- 2 years ago
From the device handbook, it mentioned that the Cyclone III device family does not
contain dedicated serialization or deserialization circuitry. Therefore, shift registers,
internal phase-locked loops (PLLs), and I/O cells are used to perform serial-to-parallel conversions on incoming data and parallel-to-serial conversion on outgoing data. The differential interface data serializers and deserializers (SERDES) are automatically constructed in the core logic elements (LEs) with the Quartus® II software ALTLVDS megafunction.
AqidAyman_Altera
2 years agoHello,
I wish to follow up with you on this issue,
Is there any more support needed?
Aqid
