Compiling Encrypted Design Files
I'm attempting to compile the Megacore Triple Speed Ethernet module for sumulation using Active HDL. I want to compile the library files into a resource library and attach that to my simulation. However, the sources are encrypted, and the tool bombs out. How do you all handle that issue? I've been searching for a couple days. I'm also in communication with Aldec about this, but progress has been slow. I can't believe I can't find a published solution:evil:
Thanks in advance.4 Replies
Did you notice the eda tab in the MegaWizard for TSE? It's about your problem.
Hi, thanks for your response. I tried the EDA tab, but got this message:
--- Quote Start --- Error: Ethernet HDL generation failed. Info: ethernet: IP Functional simulation Model Creation Failed. The following error was returned. --- Quote End --- I guess I don't have the required simulation libraries. - Altera_Forum
O.K., possibly something is missing. However, there's no other way for functional simulation of the encrypted cores than using the special simulation libraries. I don't use TSE and don't know about possible general issues, but it works well with other cores.
Thanks again. Something is definitely missing. I'm researching it now. I'll upudate when I have a solution.
