11 years agoCompilation in DSP builder
when i am double clicking signal compiler and select use board block to specify devices then the message "Error No board component find" can anybody suggest what be the solution?
1 Reply
This should be due to you does not include a board block into your design. If you are using custom block then you might need to create a new library, else you can just input the device number without click the board block
