11 years agoCompilation in DSP builder
when i am double clicking signal compiler and select use board block to specify devices then the message "Error No board component find" can anybody suggest what be the solution?
11 years agoThis should be due to you does not include a board block into your design. If you are using custom block then you might need to create a new library, else you can just input the device number without click the board block
