17 years agoClocked Video Output slave control not functioning
I have not successfully gotten Clocked Video Output to take dynamic configuration from it's slave port. I can use the wizard to configure it, but none of the 1-14 video modes will configure. Ye...
16 years agoThanks, but I must say we did it together. Next step is adding a Alpha blender and a few more frame readers. After that I will try to implement Linux on the neek with use of the LCD.
The reason you have to create a new bsp file is because of the directory names I've changed (had to do it myself as well) Sorry for that! I'll keep you posted! Good luck with your projects as well! Ciao Hans ;)
