17 years agoClocked Video Output slave control not functioning
I have not successfully gotten Clocked Video Output to take dynamic configuration from it's slave port. I can use the wizard to configure it, but none of the 1-14 video modes will configure. Ye...
16 years agoVery nice, I just tried it and works well. Only thing you have got to do is, to switch the linker to work with the ssram instead of the ddr_sdram and switch the exceptions to ssram in the BSP-Editor if you work with a new project.
Nice work, I will have to take a closer look how you have done it when I have got some spare time. Will implement this in another project. Good luck with your further projects Hans! That was a nice teamwork.
