17 years agoClocked Video Output slave control not functioning
I have not successfully gotten Clocked Video Output to take dynamic configuration from it's slave port. I can use the wizard to configure it, but none of the 1-14 video modes will configure. Ye...
17 years agoOh i am not very experienced in the video projects. So i might not be very expert in giving solutions.
But have worked on the 3c120 development board and got the TV output working. And while working on this project, i came accross the problems which i found similar to your posting. So suggested the solutions, which i thought, you would find useful. anyways, i know for 720x576 active resolution, as per the standard, its 864x625 and thus 27 MHz. But i was telling about the TV output mode(mode 22) on CH7010d (Bitec Quad video board), which has 882x625 as actual resolution. but i think, you would be able to find solution for this particular board and problem better than me. all the best!
