17 years agoClocked Video Output slave control not functioning
I have not successfully gotten Clocked Video Output to take dynamic configuration from it's slave port. I can use the wizard to configure it, but none of the 1-14 video modes will configure. Ye...
17 years agoThis is not my first video project, I deal with such stuff now for 10 years, and also helped to well known chip maker companies in some chip development too, so I believe I know a lot about the encoder chips and the standards, resolutions.
But talking about the concrete problem... The encoder chip I use is my labor encoder and is used now for many years for different source testing, and of course it works with any other source. 882x625??? The active pixel resolution is 720x576 by the ITU BT or CCIR 601. Together with H blanking pixels is 864 (1728 bytes with TRS). V resolution is 625 (inc. VBI lines). 1728 x 625 x 25 (full frame == 50 interlaced) = 27 000 000, so that 27 Mhz.
