17 years agoClocked Video Output slave control not functioning
I have not successfully gotten Clocked Video Output to take dynamic configuration from it's slave port. I can use the wizard to configure it, but none of the 1-14 video modes will configure. Ye...
17 years agoThe application is very-very simple. There is no external source. The source is a Test pattern Gemerator with approriate parameters (720x576, YCbCr, 4:2:2, 8 bit wide, sequence, interlaced). Just two componets are in the NIOS, this pattern generator, and the Clocked Video Output which has these parameters:
720x576, 8 bit, numof CP 2, sequence,, Interlaced, Emb. in video., PAL template is apllied, btw. Use control port is checked on, BUT I STILL DON'T HAVE ACCESS to the parameters in runtme.
