17 years agoClocked Video Output slave control not functioning
I have not successfully gotten Clocked Video Output to take dynamic configuration from it's slave port. I can use the wizard to configure it, but none of the 1-14 video modes will configure. Ye...
17 years agoOh Sorry. I assumed, you are using separate sync signals and not embedded with video.
Currently i don't have the development board to verify the clocked video output behavior. But may i ask, from where does this PAL video comes and what is the pixel clock and how is it generated. Just a suggestion, you can verify the altera avalon ST video control packets preceding the video frame and verify the resolution and format.
