17 years agoClocked Video Output slave control not functioning
I have not successfully gotten Clocked Video Output to take dynamic configuration from it's slave port. I can use the wizard to configure it, but none of the 1-14 video modes will configure. Ye...
17 years agoHi,
Thank you for your answer. ... you haven't specified all the parameters. address 28 - horizontal front porch address 29 - horizontal sync address 30 - horizontal blank and for the vertical parameters, you haven't configured for register 34, 35, 36 , which are specially for interlaced video. It is not needed to specify these parameters if I use embedded syncs. And with embedded syncs there is no chance to adjust anything at the video encoder, not to mention, that is unnecessary. Broken means broken :-)) How can I specify.... So the picture is aligned well, but the inside part like a Picasso picture and everything is changing. So, I still don't have diea how can I read the registers, then after this how can I set them. Any help is greatly appreciated!
