17 years agoClocked Video Output slave control not functioning
I have not successfully gotten Clocked Video Output to take dynamic configuration from it's slave port. I can use the wizard to configure it, but none of the 1-14 video modes will configure. Ye...
17 years agoI have exactly the same problem. I cannot modify any setting. The difference is that I go with PAL / interlaced 720x576. I have tried this:
IOWR(VOUT_BASE, 41 , 0); // mode-2 invalid IOWR(VOUT_BASE, 23 , 1); // interlaced 4 IOWR(VOUT_BASE, 24 , 720); // F0 width 5 IOWR(VOUT_BASE, 25 , 288); // F0 height 6 IOWR(VOUT_BASE, 26 , 720); // F1 width 7 IOWR(VOUT_BASE, 27 , 288); // F1 height 8 IOWR(VOUT_BASE, 30 ,144); // HORIZONTAL BLANK 11 IOWR(VOUT_BASE, 33 , 2); // F1 vertical blank in lines 14 IOWR(VOUT_BASE, 36 , 24); // F0 vertical blank in lines 17 ?????? IOWR(VOUT_BASE, 37 , 23); // first active line 18 IOWR(VOUT_BASE, 38 , 311); // VBI rising edge line in F0 19 ????? IOWR(VOUT_BASE, 39 , 313); // F1 rising edge line# 20 IOWR(VOUT_BASE, 40 , 0); // F1 falling edge line# 21 VO->stop(false); // stop(VOUT_BASE,1); IOWR(VOUT_BASE, 22 , 0); // mode-1 invalid IOWR(VOUT_BASE, 41 , 1); // mode-2 valid VO->start(); // start(VOUT_BASE); No luck, nothing happens, the picture on the output is broken. It looks like some syncron problem I have. When I try to ask what are the current settings, I get a lot '1': interlaced: 1 active_picture_width: 1 active_picture_height: 1 active_picture_width_f1: 1 active_picture_height_f1: 1 horizontal_front_porch: 1 horizontal_sync: 1 horizontal_blanking: 1 vertical_front_porch: 1 vertical_sync: 1 vertical_blanking: 1 vertical_front_porch_f0: 1 veritcal_sync_f0: 1 veritcal_blanking_f0: 1 active_picture_line: 1 vertical_blank_rising_edge: 1 field_rising_edge_line: 1 valid: 1 It does not matter which mode I try to reach. Even if I dump the whole memory around that address, I get only ones. IMHO this is again some part from Altera what is not documented well at all. Any help?
