17 years agoClocked Video Output slave control not functioning
I have not successfully gotten Clocked Video Output to take dynamic configuration from it's slave port. I can use the wizard to configure it, but none of the 1-14 video modes will configure. Ye...
17 years agoBeautiful! I got it working in two tries.
Once you confirmed the documentation was correct that there are 19 registers, and not 18, I implemented that and stuck with it. I was setting back porch values (from the wizard) in the blanking setter functions. Oops. This was causing flicker. Register number 3 is a hot register with only one bit active at any given time. So it was returning powers of 2 only. I now have my getter take the log_2 of the hot register value to correctly detect the currently active mode. Yay!
