17 years agoClocked Video Output slave control not functioning
I have not successfully gotten Clocked Video Output to take dynamic configuration from it's slave port. I can use the wizard to configure it, but none of the 1-14 video modes will configure. Ye...
17 years agoHi,
I could configure the clocked video output IP of version 8.0 for different modes. i left the registers for mode 1 untouched. and configured the registers for mode 2 and then set mode-1 invalid and mode-2 valid respectively. make sure, you are following this order. - start clock video output IP - set mode-2 invalid - configure register values for mode-2 -stop clocked video output ip -set mode-1 invalid -set mode-2 valid -start clocked video output IP hope this would help. Regards, Foram
