16 years agoCan i dsp buider abd multiprocessor capabilities together
Helo I want to know if it is possible to use DSP Buider and Multiprocessor capabilities together. What board Should I use? Can I run the appplication on DE2 board?
as long as you have enough logic in your target device and meet fmax, sure. the DE2 could work as long as it meets your requirements.
Is DE2 Board capable of running Multiprocessor system?Or is it possible to run the application using ISS(Instruction Set Simulator) i.e. without hardware support.
