16 years agoCan i dsp buider abd multiprocessor capabilities together
Helo I want to know if it is possible to use DSP Buider and Multiprocessor capabilities together. What board Should I use? Can I run the appplication on DE2 board?
16 years agoIs DE2 Board capable of running Multiprocessor system?Or is it possible to run the application using ISS(Instruction Set Simulator) i.e. without hardware support.
