11 years ago
Bug in V Series Avalon MM for PCI Express
When using this component with QSYS (even with a simple example) a compilation error is obtained, because tlbfm_out is declared as OUTPUT in the VHLD/Verilog that references the component pcie_256_avmm_port, when it should be INPUT.
The fix is simple
In the file <quartus instalation directory>\ip\altera\altera_pcie\altera_pcie_hip_256_avmm\pcie_256_avmm_port.tcl
in the lines
add_to_no_connect tlbfm_in 1001 out
add_to_no_connect tlbfm_out 1001 in
replaces "out" by "Output" and "in" by "Input".
Best regards.
