avl_address order in uniphy ip
Hi Sir,
I am working on SEN02G64C4BH2MT-30WR DDR2. i am using uniphy ip in quartus. (Stratix 4)
I am able to do single write and read to a particular address location with specific data.
For bulk data read and write, i incremented address location and data by one, in top vhdl file (avl_addr = avl_addr +1 and avl_wdata = avl_wdata + 1). but am i missing some of data.
pll_ref_clk = 100MHz.
afi_clk = 266.66 MHz
MEM_CLK = 133.33Mhz (half rate).
JERIN
- sstrell
Remember that with Avalon in Platform Designer, masters, by default, use byte addressing while slaves, like the memory IP, use word addressing. You don't mention what your data width is, but if, for example, it's 32 bits, you need to increment the address by 4 on the master to get to the next 32-bit data.
#iwork4intel
- Deshi_Intel
HI,
sstrell has a point.
Besides that, you also want to watch out if there is burst setting in your DDR2 avalon transaction.
dlim
- JJame30
Sir,
My parameters are:
avl_size , i kept as 0001
avl_wdata = 256 bit
mem_dq = 64 bit (half rate)
avl_addr = 26 bit
My initial address was X"0000000", for increasing address location by 1(X "0000001"), i want to add 4 with avl_addr ?
- Deshi_Intel
HI,
Another thing to watch out is the DDR2 IP local_be signal, byte enable signal setting.
Feel free to try and error to increment the avl_addr as it's unclear which path in your design is facing the issue now
One thing to take note is you can add signal_tap to monitor your avalon bus transaction to see where thing goes wrong to figure out the issue is with your avalon master or any QSYS interconnect bridge or on your DDR2 IP avalon slave side
dlim
- JJame30
ok sir. Thankyou
- Deshi_Intel
welcome
- Deshi_Intel
HI,
Hopefully everything goes well with your issue debug
For now, I am setting this case to closure.
dlim
