Arria10 no "EMIF_USR_CLK" out( DDR4), thus "EMIFDebug KIT" says “Could not accurately determin conne
I recommend that you check the following points :-
The DDR IP pll ref clock and the memory output clock to the DDR devices are both running and at the correct frequencies.
The DDR IP global_reset_n signal is high
Try reducing the frequency of the JTAG clock signal and see if this helps. See KDB :
If these points don't help, can you confirm if your project is just the auto-generated example design project generated from the DDR IP or does it contain additional logic from your design ?
Intel Forum Support
- JET602006 years ago
Contributor
Thanks @Rashmi1 for suggestion,
we rollback to use Quartus Standard 18.1 to generate an EMIF Example Design, and it succeed to run on our A10SOC board. You can close this ticket. Thanks for help ~
- APPU_appu4 years ago
Hi Rashmi /JET60200
while debugging the DDR IP, i am getting the error like "Could not accurately determine connection type for connection PCIe_SUB_SYATEM|ddr4|emif_0|col_if|colmaster as the clock of the connection is inactive "
can u please let me know how to debug this issue above one i tried but it is not working
