Arria V from TSE to 2.5G
A system is currently using an Arria V with the Triple Speed Ethernet IP in PCS only configuration. The design is successfully communicating with other SGMII capable devices at 10/100/1000 speeds.
A requirement arose to add 2.5G SGMII support on the same device maintaining backwards compatibility with the lower 10/100/1000 speeds we already support.
What Intel IP can support that ?
- paveetirrasrie_Altera
Good day to you.
You may consider V-Series Transceiver PHY IP :
Pavee
- host
Thanks for your input.
The FPGA in question is an Arria V: 5AGXBA5D6F35C6
1. Will this IP work on any GBx transceivers the device has ?
2. What about lower speeds ? Can the IP you suggested support 10/100/1000 as well as 2.5G ?
Yes it can be done but we have not validated it.
What I would suggest is if you want to support both backplane 2.5G and standard 10/100/1000M, you may use TSE IP for SGMII interface and use transceiver PHY IP for 2.5G SGMII/1000Base-X and add control logic to switch interfaces based on detected link type.
Pavee
- host
Regarding your suggesting of "add control logic to switch interfaces based on detected link type"
How do you suggest to do that ?
From what I see, the IP populates the fabric up to and including the transceiver pin.
Are you suggesting to add some kind of high speed transceiver MUX between the 2.5G and 10/100./1000M IPs and the FPGA transceiver pin ?
Good day to you.
Yes, you may need control logics to identify which interface is active, MAC selection MUX which routes TX/RX data based on control logic but need to ensure only one MAC path is active at a time.
Pavee
Good day to you.
Kindly let me know if my previous suggestion helps.
Pavee
We didn't hear from you since last update. If you have a new question, feel free to open a new thread to get the support from Altera experts.
Thank you.
