host
1 year agoArria V from TSE to 2.5G
A system is currently using an Arria V with the Triple Speed Ethernet IP in PCS only configuration. The design is successfully communicating with other SGMII capable devices at 10/100/1000 speeds. ...
paveetirrasrie_Altera
1 year agoHello,
Good day to you.
You may consider V-Series Transceiver PHY IP :
Pavee
host
1 year agoThanks for your input.
The FPGA in question is an Arria V: 5AGXBA5D6F35C6
1. Will this IP work on any GBx transceivers the device has ?
2. What about lower speeds ? Can the IP you suggested support 10/100/1000 as well as 2.5G ?
