host
1 year agoArria V from TSE to 2.5G
A system is currently using an Arria V with the Triple Speed Ethernet IP in PCS only configuration. The design is successfully communicating with other SGMII capable devices at 10/100/1000 speeds. ...
host
1 year agoRegarding your suggesting of "add control logic to switch interfaces based on detected link type"
How do you suggest to do that ?
From what I see, the IP populates the fabric up to and including the transceiver pin.
Are you suggesting to add some kind of high speed transceiver MUX between the 2.5G and 10/100./1000M IPs and the FPGA transceiver pin ?
