host
1 year agoArria V from TSE to 2.5G
A system is currently using an Arria V with the Triple Speed Ethernet IP in PCS only configuration. The design is successfully communicating with other SGMII capable devices at 10/100/1000 speeds. ...
paveetirrasrie_Altera
1 year agoHello,
Good day to you.
Yes, you may need control logics to identify which interface is active, MAC selection MUX which routes TX/RX data based on control logic but need to ensure only one MAC path is active at a time.
Pavee
