Arria 10 Native PHY 66:64 RX wrong word with valid asserted
I am using Arria 10 Native PHY in Basic Enhanced PCS mode at 12.5 Gbps for a custom protocol.
The protocol layer is implemented in FPGA fabric. The Native PHY is intended to provide the serial transceiver path and the Enhanced PCS 66b gearbox only. The fabric provides one 66b block per clk_sys: 2-bit sync/control header + 64-bit payload
The goal is a non-backpressure full-rate interface: one 66b TX block accepted every clk_sys, and one 66b RX block produced every clk_sys after RX lock.
I've attached the .tcl to generate the core, but some of the key config parameters are:
protocol_mode = basic_enh
data_rate = 12500
enh_pld_pcs_width = 66
enh_pcs_pma_width = 64
TX 64b/66b encoder = disabled
RX 64b/66b decoder = disabled
TX scrambler = disabled
RX descrambler = disabled
RX block synchronizer = enabled
TX FIFO mode = Phase Compensation
RX FIFO mode = Phase Compensation
double width = disabled
10GBASE-R insert/delete = disabled
Interlaken deletion features = disabledClocking:
clk_sys <= tx_clkout(0);
tx_coreclkin <= (others => clk_sys);
rx_coreclkin <= (others => clk_sys);Controls:
tx_enh_data_valid <= (others => '1');
rx_enh_fifo_rd_en <= (others => '1');
tx_pma_elecidle <= (others => '0');66b mapping:
(inside a loop that iterates for every channel 'c')
tx_parallel_data((c+1)*64-1 downto c*64) <= tx_data(c)(63 downto 0);
tx_control((c+1)*2-1 downto c*2) <= tx_header(c)(1 downto 0);
rx_data(c)(63 downto 0) <= rx_parallel_data((c+1)*64-1 downto c*64);
rx_header(c)(1 downto 0) <= rx_control((c+1)*2-1 downto c*2);Observed in serial loopback simulation:
With RX FIFO in RX Register mode, rx_enh_data_valid has periodic bubbles, apparently matching the 66:64 gearbox cadence.
With RX FIFO in RX Phase Compensation mode, rx_enh_data_valid stays asserted, but rx_parallel_data periodically has a whole-word discontinuity. It looks like a 66b word is skipped/repeated, or the latency changes by one word. The event periodicity is about 160 ns, close to the expected 66:64 gearbox cadence.
These two captures are from a sequence where I receive wrong data with rx valid asserted (the first is the tx'ed sequence and the second the received:
To make the issue clear I mapped the word to a letter to make it easier to see the issue:
In the capture above there is the tx and rx sequence, and can be seen where the pattern breaks compared to tx.
My question is:
For Arria 10 Native PHY Basic Enhanced PCS with enh_pld_pcs_width=66, enh_pcs_pma_width=64, and RX FIFO in Phase Compensation mode, is a continuous non-backpressure 66b RX stream supported?
If yes, what configuration or clocking condition could cause a periodic one-word wrong while rx_enh_blk_lock, rx_enh_data_valid, and rx_control remain stable?
Thanks in advance.
