10 years agoArria 10 External Memory Interface Invalid Data Width
I am using the External Memory Interface IP core in Qsys to connect to a DDR3 daughter memory card through the Arria 10 GX FPGA Development Kit via the HiLo interface. I am also using an address span...
10 years ago --- Quote Start --- I am using the External Memory Interface IP core in Qsys to connect to a DDR3 daughter memory card through the Arria 10 GX FPGA Development Kit via the HiLo interface. I am also using an address span extender between the CPU and EMI the connects to the EMI's ctrl_amm_0 port; there is an error claming that the data width of this connection must be of power of two and between 8 and 4096. I'm not sure how to check the current data width or what I need to change to get the size to a power of two. --- Quote End --- I had the same issue in Qsys and resolved it by regenerating the EMIF core wtih a DQ width of 64 (8 pins per DQS group) instead of the 72 that is supported on my board. I was able to generate the core outside of Qsys using the IP Parameter Editor though without any problems.
Jacky_chang
2 years agohji
about
"regenerating the EMIF core wtih a DQ width of 64 (8 pins per DQS group)"
Is there a picture of the regenerating process?
I have the same problem
address width above 32 bits are not supported in nios 2
