PCIe bringup in Agilex 5
I am working on PCIe bring-up on an Intel Agilex 5 SoC FPGA platform using the Altera PCIe Root Port IP in Root Port mode.
Current status:
PCIe root port is detected properly
NVMe endpoint is also enumerated correctly
lspci shows both root port and NVMe device successfully
However, I am facing two major issues:
During NVMe probe, I sometimes get:
nvme nvme0: I/O tag 0 (1000) QID 0 timeout, completion polled
If probe succeeds and I try actual read/write operations on the NVMe drive, the system crashes/hangs with RCU stall or timeout related logs.
I have already checked:
PCIe link comes up correctly
BARs are assigned
Bus master enabled
Endpoint enumeration looks fine
I also tried:
pci=nomsi
but then NVMe probe fails with error -22.
This makes me suspect the issue may be related to:
MSI/MSI-X interrupt handling
DMA configuration
outbound address translation
or cache coherency issues
Has anyone seen similar behavior on Agilex 5 or Altera PCIe Root Port IP where:
enumeration works
but NVMe probe times out or crashes during I/O?
Any suggestions on what to debug next would be very helpful.
1 Reply
- KianHinT_altera
Hi Sweth ,
I'm assigned to this forum case and I believe that you have already had an APS case open on this and we will discuss through there. Anyway I will leave this forum post open to see anyone had any past experiences with this.
Kian
