mjj67's avatar
mjj67
3 months ago
GTS JESD204C IP Evaluation Mode not working
Using Quartus Pro 25.3 I can't generate time limited sof for GTS JESD204C. I have reviewed Licensing 'know-How' Guild. I found and corrected an issue with the LM_LICENSE_FILE variable. I have verified that IP Evaluation Mode is enabled within Quartus. I'm working with the GTS JESD204C Example Design generated with Platform Designer selecting the "Agilex 5 E-Series 065b Premium Development Kit". I'm also using the GTS JESD204C IP Design Example User Guild. When I compile the design I get Message ID 23714 "Can not generate programming files", 115005 "Unlicensed IP: JESD204C (6AF7 0146)", and 115004 "Unlicensed encrypted design file". At this time, I'm only interested in evaluating the GTS JESD204C IP. Does this IP support evaluation mode? If so, any suggestions as to why Quartus Pro will not generate time-limited sof files?
  • CheepinC_altera's avatar
    CheepinC_altera
    Based on my understanding, you are observing an issue during Quartus compilation where the GTS JESD204C IP is unable to generate a time‑limited SOF. After reviewing the GTS JESD204C IP User Guide, this IP should support evaluation mode.
    To help determine whether this is a Quartus version–dependent issue, or whether it has already been addressed in a newer release, could you please try compiling the same design using Quartus 26.1 and let us know if the issue persists?
    Please let me know if you have any questions or concerns. Thank you.
    • mjj67's avatar
      mjj67
      Thank you for the reply. I was in the process of installing 26.1 Pro when you replied. I successfully installed Quartus Pro 26.1 and verified SHA1 was good on the download. I opened my project and instead of using "Upgrade IP" I chose to do this manually via Platform Designer. Both qsys files failed to generate with exit code 3.
      I documented all of the setting I used when I created this project and have decided to recreate this from scratch under 26.1 to see what happens. I'll report back when finished to let you know how it turns out.
      • mjj67's avatar
        mjj67
        I confirm that recreating the GTS JESD204C example design from scratch under Quartus Pro 26.1 produced a time-limited sof file; however, timing requirements not met. This could be related to the setting I used in the IP.
        Additional notes:
        • When I generated the example designe it ends with Error: Failed to generate example_design
        • Close Plaform Designer and select NO for "Recent changes have not been generated. Generate now?"
        • Under Quartus goto File > Open Project
        • Navigate to the generated project <original project path> jesd204c_gts_0_example_design > ed > quartus > jesd204c_gts_ed_rx_tx.qpf
        • If asked to close current project, Click Yes
        • Open Platform Designer
        • For Platform Designer system, Navigate to <original project path>  jesd204c_gts_0_example_design > ed > rtl > du > j204c_gts_rx_tx_ip.qsys (this is a sub-system)
        • For "Open System Completed", Click Close
        • Click "Generate HDL..."
        • I checked "Include Altera attributes in generated HDL to detect interfaces in Node Finder and RTL Analyzer"
        • Click Gernerate
        • I got "Generate: completed with warnings." Click Close
        • Platform Designer, Open File
        • For Platform Designer system, Navigate to <original project path>  jesd204c_gts_0_example_design > ed > rtl > du > j204c_gts_rx_tx_ss.qsys (this is the top-level qsys)
        • Close Platform Designer
        • Under Quartus, Compile
        • I got "Full Compilation was successful (22 warnings)"
        • Using windows file explorer I confirmed that jesd204c_gts_rx_tx_time_limited.sof was created.
