13 years ago
AltPll Dynamic phase shift state machine
Hi everyone,
I am trying to implement a design for generating a dynamic phase shift clock output. I am using cyclone III device for my design. I have gone through the documentation to implement dynamic phase shift ( http://www.altera.com/literature/an/an507.pdf ) I found a statemachine implimentation description to controle the parameters of the pll. I have implemented the statemachine as described in the document but it doesn't seem to work. If any body implemented the statemachine,could you please help me .
sarat
    Did you check in hardware or gatelevel simulation? If in hardware, can you show a signaltap recording of the relevant signals?
    The statemachine is working fine. I have tested it with signal tap.below you find the code.
    library ieee;
    use ieee.std_logic_1164.all ;
    use ieee.std_logic_arith.all ;
    entity dynamic_input is
    port (
    clk : in std_logic ;
    choose_op : in std_logic_vector ( 1 downto 0 ); -- "01" to shift down the phase,"10" to shift up the phase and others no effect
    phase_counter_sel_in : in std_logic_vector ( 2 downto 0 );-- for selecting output clock to be shifted
    phase_counter_sel_out : out std_logic_vector ( 2 downto 0 );
    phase_up_down : out std_logic ;-- when '1' shifts phase up '0' shifts down
    phasestep : out std_logic ;--to enable phase shift process
    phasedone : in std_logic ;
    --scan_clk : out std_logic ;
    --state_out : out std_logic_vector (1 downto 0 )
    end entity dynamic_input;
    architecture behaviour of dynamic_input is
    type state is ( init , phase_up , phase_down , wait_up , wait_down , wait_shiftend , wait_phasedone );
    signal pr_state : state ;
    signal next_state : state := init ;
    begin
    --scan_clk <= clk ;
    phase_counter_sel_out <= phase_counter_sel_in ;
    process ( clk )
    begin
    if ( clk = '0' and clk'event ) then
    pr_state <= next_state ;
    end if ;
    end process ;
    process ( pr_state )
    begin
    case pr_state is
    when init =>
    --set initial values to the dynamic parameters--
    phasestep <= '0' ;
    phase_up_down <= '0' ;
    if ( choose_op = "10" ) then
    next_state <= phase_up ;
    elsif ( choose_op = "01" ) then
    next_state <= phase_down ;
    else
    next_state <= init ;
    end if ;
    when phase_up =>
    phasestep <= '1' ;
    phase_up_down <= '1' ;
    next_state <= wait_up ;
    when phase_down =>
    phasestep <= '1' ;
    next_state <= wait_down ;
    when wait_up =>
    phasestep <= '1' ;
    next_state <= wait_phasedone ;
    when wait_down =>
    phasestep <= '1' ;
    when wait_phasedone =>
    if ( phasedone = '0' ) then
    phasestep <= '0' ;
    next_state <= wait_shiftend ;
    end if ;
    when wait_shiftend =>
    if ( phasedone = '1' ) then
    end if ;
    end case ;
    end process ;
    end behaviour ;
