Altpll_0: Port phasecounterselect has width 3 in TCL, but 34 in the design file
I'm using Cyclone 10 LP development kit, and I'm building a qsys in Quartus 18.1 prime lite version.
I use altpll intelFPGA IP in qsys, when I generate VHDL code for qsys, I get the error "Error : altpll_0: Port phasecounterselect has width 3 in TCL, but 4 in the design file".
I followed the following link to modify the altera_avalon_altpll_hw.tcl, but it does not solve the problem. I realized that the error is different from the one in the link which has 4 in TCL, but 3 in the design file. http://ftp.beckhoff.com/download/document/io/ethercat-development-products/ethercat_ipcore_datasheet_addendum_v2i5.pdf
Can anybody help me with this?
Thank you very much in advance!
Jasmine
- Vicky1
Could you please check the below solution?
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/rd07202015_476.html
please let me know , how it works for you.
Vicky
- Mingyuexin
Hi Vicky,
Thank you very much for the answer.
Actually I fixed it by myself by remove the altpll ip and add an new altpll ip again without changing altera_avalon_altpll_hw.tcl.
The reason could be that I copied the qsys from somewhere (either from my previous design for MAX or from an example design for cyclone 10 LP in an older Quartus version).
With best wishes
Jasmine.
- Vicky1
Hi Jasmine,
Glad to know that you could able to resolve the issue by yourself.
Vicky
