16 years agoAll avalon singnal sync to avalon bus clock
sorry for my noob question. im a bit new to avalon bus architechture.
--- Quote Start --- Synchronous Interface — All Avalon signals are synchronized to the Avalon bus clock. This simplifies the relevant timing behavior of the Avalon Bus, and facilitates integration with high-speed peripherals. --- Quote End --- i read this in avalon bus spec : https://www.alteraforum.com/forum/attachment.php?attachmentid=2421 1.by avalon bus clock does it mean the clock we fed to the processor? If so... how about an SOPC system without any processor? for example in a system like below this. what is exactly the freq of avalon bus? How can i determine it? https://www.alteraforum.com/forum/attachment.php?attachmentid=2422 2. what does this sentence actually meant "this simplifies the relevant timing behavior of the avalon bus,and facilitates integration with high-speed peripherals" Does it mean that i dont have to worry about syncronization between slower peripheral and highspeed connected to the avalon bus?
Any Avalon device uses the clock specified in the clock columns of sopc builder.
If you have modules using different clocks, you need a clock crossing bridge to match them. You can find further (and more trustable...) information in the following document:
(see for example page 3.9)http://www.altera.com/literature/tt/tt_nios2_system_architect.pdf - Altera_Forum
--- Quote Start --- Any Avalon device uses the clock specified in the clock columns of sopc builder. If you have modules using different clocks, you need a clock crossing bridge to match them. You can find further (and more trustable...) information in the following document:
(see for example page 3.9) --- Quote End --- thanks for the documentation and quick reply..:)http://www.altera.com/literature/tt/tt_nios2_system_architect.pdf
