16 years agoaclr and sclr - difference
Hi, can someone please explain me why some DSP builder blocks have aclr and others sclr input ? what's the difference and how does it influence the generated vhdl code ? Thanks ppl !
16 years agoI can not agree more with you. However, you do not answer my questions. This is DSP Builder Forum, therefore my questions are related to the DSP Builder Altera Blockset.
I was previously asking about a block called 'Clock Block' where one can set the aclr reset flank to active low/high. The question was, whether this setting has an influence on aclr input of other blocks. The second question was related to a block called ' Global Reset Block'. To be even more clear I say it once more - I DO NOT have any problems with setup/hold/metastability violations. I was asking about DSP Builder Blockset behaviour bacause I was to lazy to check the generated vhdl files. I hope this is clear now, best regards
