1 Reply
The perstn from motherboard needs connect to pin_perst of pcie core.
If the Arria V FPGA has 2 PCIe cores, each PCIe core instance has its own pin_perst signal. You must connect the pin_perst of each Hard IP instance to the corresponding nPERST pin of the device. These pins have the following locations: - NPERSTL0: bottom left Hard IP block - NPERSTR0: bottom right Hard IP block
