12 years agoa5,hard ip of pcie,how connect perstn?
the perstn from pc mother board`s pcie slot is not connect to the dedicated io pin of arria5, when fit, error report.how can i fix it?
11 years agoThe perstn from motherboard needs connect to pin_perst of pcie core.
If the Arria V FPGA has 2 PCIe cores, each PCIe core instance has its own pin_perst signal. You must connect the pin_perst of each Hard IP instance to the corresponding nPERST pin of the device. These pins have the following locations: - NPERSTL0: bottom left Hard IP block - NPERSTR0: bottom right Hard IP block
