assn1's avatar
assn1
4 years ago
a problems about using negative clk
The port definition is complete, but errors continue to occur.
always @(negedge clk_1Msec or negedge rst) begin
if(Control == 0) begin
if(rst == 0) begin
Msecs <= 0;
Mins <= 0;
Secs <= 0;
Hours <= 0;
Check <= 0;
This is it;
Error (10200): Verilog HDL Conditional Statement error at stopwatch.v(43): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct
I couldn't find a grammatical error. I need help.
  • ak6dn's avatar
    ak6dn
    Well, that is not complete verilog. For one, it is missing three end statements corresponding to the begin statements.
    posedge clk or negedge clk does not matter; neither will work as you wrote the verilog.
    Then, the if (control == 0) begin statement uses a signal not in the sensitivity list (control) ...
    ... but embedded within that block is the if (rst == 0) begin statement which DOES use a signal in the sensitivity list (negedge rst).
    That makes no semantic sense and does not translate to real logic.
    So rewrite and repost a version of that always block that is meaningful, something like this ...
        begin
        if (rst == 0)
            begin
            xxx <= 0;
            end
        else
            begin
            if (control == 0)
                begin
                xxx <= xxx + 1;
                end
            end
        end
    And use the <code> block to make your code easily readable.
    • assn1's avatar
      assn1
      Thank you for your help. But I want to measure the laptime; to store the time-varying values where the clk jumps, I have to let it occur at the end of the cycle at the clk of the falling edge.
      Here's the stopwatches module code. Could you please help me a little more?
      <code>
      module stopwatch(
      clk_1Msec,
      rst,
      laptime,
      Hours_L,
      Mins_L,
      Secs_L,
      Msecs_L,
      Start_S,
      Stop_S,
      rst_S,
      Hours_S,
      Mins_S,
      Secs_S,
      Msecs_S,
      Control);
      input clk_1Msec, rst, Start_S, Stop_S, rst_S, Control, laptime;
      output [3:0] Hours_S;
      output [5:0] Mins_S, Secs_S;
      output [9:0] Msecs_S;
      reg [9:0] Msecs;
      reg [5:0] Mins, Secs;
      reg [3:0] Hours;
      reg [9:0] Msecs_L;
      reg [5:0] Mins_L, Secs_L;
      reg [3:0] Hours_L;
      reg [1:0] Check;
      assign Msecs_S = Msecs;
      assign Secs_S = Secs;
      assign Mins_S = Mins;
      assign Hours_S = Hours;
      always @(negedge clk or negedge rst) begin
      if(rst == 0) begin
      Msecs <= 0;
      Mins <= 0;
      Secs <= 0;
      Hours <= 0;
      Check <= 0;
      Msecs_L <= 0;
      Mins_L <= 0;
      Secs_L <= 0;
      Hours_L <= 0;
      end
      if(laptime == 1) begin
      Hours_L = Hours_S;
      Mins_L = Mins_S;
      Secs_L = Secs_S;
      Msecs_L = Msecs_S;
      end
      end
      end
      always @(posedge clk or negedge rst) begin
      if(rst == 0) begin
      Msecs <= 0;
      Mins <= 0;
      Secs <= 0;
      Hours <= 0;
      Check <= 0;
      Msecs_L <= 0;
      Mins_L <= 0;
      Secs_L <= 0;
      Hours_L <= 0;
      end
      else begin
      if(Check + Stop_S > 0) begin
      Msecs <= Msecs;
      Mins <= Mins;
      Secs <= Secs;
      Hours <= Hours;
      Check = 1;
      if(rst_S == 1) begin
      Msecs <= 0;
      Mins <= 0;
      Secs <= 0;
      Hours <= 0;
      Check <= 0;
      end
      end
      if(!(Check + Stop_S)) begin
      if(Stop_S == 1) begin
      if(Hours == 12)
      Hours = 0;
      if(Mins == 60) begin
      Hours = Hours + 1;
      Mins = 0;
      end
      if(Secs == 60) begin
      Mins = Mins + 1;
      Secs = 0;
      end
      if(Msecs == 60) begin
      Secs = Secs + 1;
      Msecs = -1;
      end
      Msecs = Msecs + 1;
      end
      else begin
      Msecs <= Msecs;
      Mins <= Mins;
      Secs <= Secs;
      Hours <= Hours;
      end
      end
      end
      end
      end
      endmodule
      • ak6dn's avatar
        ak6dn
        The problem is your syntax for a register with an asynchronous reset is incorrect.
        It must look like as follows:
            begin
            if (rst == 0)
                begin
                data <= 0;
                end
            else
                begin
                if (control)
                    begin
                    data <= data+1;
                    end
                end
            end
        in particular this syntax is INCORRECT:
            begin
            if (Control == 0)
                begin
                if (rst == 0)
                    begin
        If you want an async reset than the test on rst must come FIRST.
        Otherwise remove the or negedge rst from the always sensitivity list and make it a synchronous reset block.
  • assn1's avatar
    assn1
    Thank you! It was very helpful.
  • SyafieqS's avatar
    SyafieqS
    This seem a syntax issue on if else condition for Verilog.
    You need to check again the correct syntax.
  • SyafieqS's avatar
    SyafieqS
    Let me know if there is any update or concern on this
  • SyafieqS's avatar
    SyafieqS
    We do not receive any response from you to the previous reply that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
