assn1
4 years agoa problems about using negative clk
The port definition is complete, but errors continue to occur.
always @(negedge clk_1Msec or negedge rst) begin if(Control == 0) begin if(rst == 0) begin Msecs <= 0; Mins <= 0; Secs <= 0; Hou...
assn1
4 years agoThank you for your help. But I want to measure the laptime; to store the time-varying values where the clk jumps, I have to let it occur at the end of the cycle at the clk of the falling edge.
Here's the stopwatches module code. Could you please help me a little more?
<code>
module stopwatch(
clk_1Msec,
rst,
laptime,
Hours_L,
Mins_L,
Secs_L,
Msecs_L,
Start_S,
Stop_S,
rst_S,
Hours_S,
Mins_S,
Secs_S,
Msecs_S,
Control);
input clk_1Msec, rst, Start_S, Stop_S, rst_S, Control, laptime;
output [3:0] Hours_S;
output [5:0] Mins_S, Secs_S;
output [9:0] Msecs_S;
reg [9:0] Msecs;
reg [5:0] Mins, Secs;
reg [3:0] Hours;
reg [9:0] Msecs_L;
reg [5:0] Mins_L, Secs_L;
reg [3:0] Hours_L;
reg [1:0] Check;
assign Msecs_S = Msecs;
assign Secs_S = Secs;
assign Mins_S = Mins;
assign Hours_S = Hours;
always @(negedge clk or negedge rst) begin
if(rst == 0) begin
Msecs <= 0;
Mins <= 0;
Secs <= 0;
Hours <= 0;
Check <= 0;
Msecs_L <= 0;
Mins_L <= 0;
Secs_L <= 0;
Hours_L <= 0;
end
if(laptime == 1) begin
Hours_L = Hours_S;
Mins_L = Mins_S;
Secs_L = Secs_S;
Msecs_L = Msecs_S;
end
end
end
always @(posedge clk or negedge rst) begin
if(rst == 0) begin
Msecs <= 0;
Mins <= 0;
Secs <= 0;
Hours <= 0;
Check <= 0;
Msecs_L <= 0;
Mins_L <= 0;
Secs_L <= 0;
Hours_L <= 0;
end
else begin
if(Check + Stop_S > 0) begin
Msecs <= Msecs;
Mins <= Mins;
Secs <= Secs;
Hours <= Hours;
Check = 1;
if(rst_S == 1) begin
Msecs <= 0;
Mins <= 0;
Secs <= 0;
Hours <= 0;
Check <= 0;
end
end
if(!(Check + Stop_S)) begin
if(Stop_S == 1) begin
if(Hours == 12)
Hours = 0;
if(Mins == 60) begin
Hours = Hours + 1;
Mins = 0;
end
if(Secs == 60) begin
Mins = Mins + 1;
Secs = 0;
end
if(Msecs == 60) begin
Secs = Secs + 1;
Msecs = -1;
end
Msecs = Msecs + 1;
end
else begin
Msecs <= Msecs;
Mins <= Mins;
Secs <= Secs;
Hours <= Hours;
end
end
end
end
end
endmodule
ak6dn
4 years agoThe problem is your syntax for a register with an asynchronous reset is incorrect.
It must look like as follows:
always @(posedge clk or negedge rst) begin if (rst == 0) begin data <= 0; end else begin if (control) begin data <= data+1; end end end
in particular this syntax is INCORRECT:
always @(posedge clk or negedge rst) begin if (Control == 0) begin if (rst == 0) begin ...
If you want an async reset than the test on rst must come FIRST.
Otherwise remove the or negedge rst from the always sensitivity list and make it a synchronous reset block.
