a problems about using negative clk
Well, that is not complete verilog. For one, it is missing three end statements corresponding to the begin statements.
posedge clk or negedge clk does not matter; neither will work as you wrote the verilog.
Then, the if (control == 0) begin statement uses a signal not in the sensitivity list (control) ...
... but embedded within that block is the if (rst == 0) begin statement which DOES use a signal in the sensitivity list (negedge rst).
That makes no semantic sense and does not translate to real logic.
So rewrite and repost a version of that always block that is meaningful, something like this ...
always @(negedge clk_1Msec or negedge rst) begin if (rst == 0) begin xxx <= 0; end else begin if (control == 0) begin xxx <= xxx + 1; end end end
And use the <code> block to make your code easily readable.
Thank you for your help. But I want to measure the laptime; to store the time-varying values where the clk jumps, I have to let it occur at the end of the cycle at the clk of the falling edge.
Here's the stopwatches module code. Could you please help me a little more?
<code>
module stopwatch(
clk_1Msec,
rst,
laptime,
Hours_L,
Mins_L,
Secs_L,
Msecs_L,
Start_S,
Stop_S,
rst_S,
Hours_S,
Mins_S,
Secs_S,
Msecs_S,
Control);
input clk_1Msec, rst, Start_S, Stop_S, rst_S, Control, laptime;
output [3:0] Hours_S;
output [5:0] Mins_S, Secs_S;
output [9:0] Msecs_S;
reg [9:0] Msecs;
reg [5:0] Mins, Secs;
reg [3:0] Hours;
reg [9:0] Msecs_L;
reg [5:0] Mins_L, Secs_L;
reg [3:0] Hours_L;
reg [1:0] Check;
assign Msecs_S = Msecs;
assign Secs_S = Secs;
assign Mins_S = Mins;
assign Hours_S = Hours;
always @(negedge clk or negedge rst) begin
if(Control == 0) begin
if(rst == 0) begin
Msecs <= 0;
Mins <= 0;
Secs <= 0;
Hours <= 0;
Check <= 0;
Msecs_L <= 0;
Mins_L <= 0;
Secs_L <= 0;
Hours_L <= 0;
end
if(laptime == 1) begin
Hours_L = Hours_S;
Mins_L = Mins_S;
Secs_L = Secs_S;
Msecs_L = Msecs_S;
end
end
end
always @(posedge clk or negedge rst) begin
if(rst == 0) begin
Msecs <= 0;
Mins <= 0;
Secs <= 0;
Hours <= 0;
Check <= 0;
Msecs_L <= 0;
Mins_L <= 0;
Secs_L <= 0;
Hours_L <= 0;
end
else begin
if(Check + Stop_S > 0) begin
Msecs <= Msecs;
Mins <= Mins;
Secs <= Secs;
Hours <= Hours;
Check = 1;
if(rst_S == 1) begin
Msecs <= 0;
Mins <= 0;
Secs <= 0;
Hours <= 0;
Check <= 0;
end
end
if(!(Check + Stop_S)) begin
if(Stop_S == 1) begin
if(Hours == 12)
Hours = 0;
if(Mins == 60) begin
Hours = Hours + 1;
Mins = 0;
end
if(Secs == 60) begin
Mins = Mins + 1;
Secs = 0;
end
if(Msecs == 60) begin
Secs = Secs + 1;
Msecs = -1;
end
Msecs = Msecs + 1;
end
else begin
Msecs <= Msecs;
Mins <= Mins;
Secs <= Secs;
Hours <= Hours;
end
end
end
end
end
endmodule
- ak6dn4 years ago
The problem is your syntax for a register with an asynchronous reset is incorrect.
It must look like as follows:
always @(posedge clk or negedge rst) begin if (rst == 0) begin data <= 0; end else begin if (control) begin data <= data+1; end end endin particular this syntax is INCORRECT:
always @(posedge clk or negedge rst) begin if (Control == 0) begin if (rst == 0) begin ...If you want an async reset than the test on rst must come FIRST.
Otherwise remove the or negedge rst from the always sensitivity list and make it a synchronous reset block.
