16 years ago2D FIR filter (from VIP Suite) only sequential?
Hello All, I'm trying to run some FIR filters on the video entering my VIP based scaling system. I'm a bit disappointed to find that (it seems) that it only works on planes in sequence. My syst...
16 years agoThe approach of splitting the parallel RGB planes to separate streams didn't work for me, i've decided to use the polyphase scaler to do my pre-scaling filtration and I'll determine my co-efficients later on - right now I'll use the presets. I'm using a post scaling sharpen filter now and I couldn't get that to work in parallel either with the re-sequencer! I'm now resequencing to serial as my bandwidth is far lower after scaling. In serial I can use the 2D fir natively and problem solved.
Sorry I can't shed more light on the approach... i've got to move on before I get sacked! Brent.
