16 years ago
1-wire (onewire) SOPC builder component
Project home:
http://opencores.org/project,sockit_owm
The source code is here:
https://github.com/jeras/sockit_owm
The GitHub version might be temporarily slightly ahead to the OpenCores version.
RTL features:
- small RTL, should fit into a CPLD
- Avalon MM bus, Wishbone compatible with a simple adapter
- timed reset, presence, write/read bit transfers
- overdrive
- power supply (strong pull-up)
SOPC Builder integration
Nios II EDS integration:
- port of the 1-wire open domain kit version 3.10b
- interrup driven or polling driver
- uCOS-II support (only partialy tested)
Known issues:
- there is no automatic detection of uCOS-II so:
-- with HAL only the polling driver works properly
-- with uCOS-II the interrupt driven driver should be used (polling disabled)
I would appreciate questions and bug reports.
Note: Tar with the component was updated to Rev 5 from OpenCores.org, equivalent to hash a8dfa48 on GitHub.com
Iztok Jeras
