RShal4
7 years agoWhy BSP project ignores "disable generation" ?
Hello, I encounter this strange behaviour: I try to disable file generation of speciifc HAL driver file. Yet, although I change it to "-" with "disable generation" and saves the settings I verif...
RShal4
7 years agoIs there any idea ?
We really struggle with it for a long time now.
EBERLAZARE_I_Intel
6 years agoHi,
This is a known bug that the option to disable BSP file generation in the Nios II BSP Editor not working properly in older version of Quartus.
The workaround is to manually edit, or script updates to the settings.bsp to re-disable the file generation (or to remove the file).
Have you try using a newer version of Quartus (17 and up)?
Regards.
- Broddo5 years ago
This bug is still present in Quartus 20.1
Are there plans to actually fix this? It's been years at this point. The only thing that's happened in the mean time is that rshal2's fix no longer seems to work.
