12 years agoWhere is the "dedicated clock output pin" of Cyclone II FPGA?
I am now using a customed Cyclone II Evaluation Module. The FPGA is EP2C8Q208C8. I managed to use the ALTPLL module to generate a 150MHz clock signal. Meanwhile, the clock signal would be output to a DAC IC. By assigning the 150M-clock-output into a GPIO, I received a warning from Quartus II : "...Use PLL dedicated clock outputs to ensure jitter performance". I do know there were dedicated clock output for each PLL. However, I don't know which pin it is. Although I tried to search the "dedicated clock output pin" in cyclone ii handbook, the result seems meaningless for me. Could you please tell me which pin in EP2C8Q208C8 is the "dedicated clock output" for PLL1? Naroah Feb/22/20142 Replies
You find the answer in the Quartus pin planner tool or the device pinout files. PLL1_OUTp is pin 47 of Q208 package.
Hi FvM,
Thank you for your reply! According to your words, I've finnally find where it is! Tnank you for your support again! Naroah Feb/23/2014
