15 years agoWhat's LVDS Setup and Hold time?
So i've read this Setup and Hold time specification from a datasheet for an ADC. I am not sure what's the meaning of it, but I am assuming that the setup and hold time for the FPGA must be higher than the setup and hold time requirement for the ADC's LVDS in order to receive the data from ADC properly. Am i right on this? or is it the other way around. Thanks. Michael4 Replies
rbugalho is absolutely right on this. The ADC setup and hold time is a constraint of not just the clock/data to output of the FPGA pins but a consequence of the path delay of each of those on the PCB board. Therefore, you need to specify the constraints of delay and clock to output from the FPGA including all the PCB path constraints etc so you can meet the setup of the ADC inputs.
--- Quote Start --- Hi, So i've read this Setup and Hold time specification from a datasheet for an ADC. I am not sure what's the meaning of it, but I am assuming that the setup and hold time for the FPGA must be higher than the setup and hold time requirement for the ADC's LVDS in order to receive the data from ADC properly. Am i right on this? or is it the other way around. Thanks. Michael --- Quote End --- The set-up and hold time given by the ADC's data-sheet specify what you are going to get at a minimum (from the ADC). You use these to make up the set_input_delay constraints for TimeQuest to guide the fitter, and to chcek the results of the compilation. On a successful compilation TimeQuest will report (considerably) shorter set-up and hold times needed by the FPGA. - Altera_Forum
Setup and hold times are properties of receivers (inputs), not transmitters (outputs).
Which means, the setup and hold times you read in the ADC's datasheet don't apply to the ADC's output signals. What is important are receiver's setup and hold times. Setup time (tSU) is the time the data signal at the receiver's input needs to be stable before the clock edge. Hold time (tH) is the time the data signal at the receiver's input needs to be stable after the clock edge. This is much easier to understand if you draw the clock and data signals for your system. You need to take into account the ADC's output timings (tCO, center or edge aligned) and the board delays for both clock and data signals. However, you won't be able to find the FPGA's tSU and tH values anywhere. :) Instead, you have to tell the FPGA's software about the input signals' timing. Then the software will adjust the FPGA's programmable input delays to meet your input signals' timing. Please read the TimeQuest cookbook for this. But basically, what you need to do is go back to that timing diagram above and figure out this: at the FPGA's input, what's the delay between the clock edge and the signal change? And you need to figure a max and min case for this. - Altera_Forum
I guess this will be help.
http://en.wikipedia.org/wiki/flip-flop_(electronics)
