SK_VA's avatar
SK_VA
7 years ago
What timing constraints can be given for setting clock skew from FPGA input to PLL output between two similar boards in a system?
I have a 100 MHz clock fed to FPGA on board from an external board.Two similar boards are present in the system.Same 100Mhz clock is fed to both boards on the system.This 100MHz clock is input to a pll in FPGA and generated a 50MHz clock.
I want to make sure that the maximum clock skew between the boards from FPGA input pin to pll output is within a range for all PVT variations.What constraints can be given for the clock path from FPGA input pin to pll output?
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    set_clock_uncertainty specifies clock uncertainty or skew for clocks or clock-to-clock transfers but it is not for performing maximum allowable skew analysis between sets of clocks.
  • SK_VA's avatar
    SK_VA
    So there is no ways to constrain this clock path?
    Can I set clock uncertainty constraints?
    KhaiChein_Y_Intel
    User can set the skew on the data path only but not the clock path. Can you set the same location in both boards ?
    KhaiChein_Y_Intel
    If the pin location for the source (FPGA input pin) and the PLL are the same in both boards, the clock delay will be the same since the boards are the same.
    • SK_VA's avatar
      SK_VA
      But the pll in both boards may not lock at the same.There might be skew in the clock output from PLL in these boards if the PLLs gets locked at different instant.
      Also these boards might be in different PVT conditions that might contribute to the skew.
    • SK_VA's avatar
      SK_VA
      Same clock is fed to two different boards in a system that performs similar function.The FPGA program that runs on both boards are same.
      I want to make sure the clock skew from the source(FPGA input pin)to PLL output that feeds my logic is within a range of ps. In hardware they have taken care that source clock reaches both FPGA at the same time. This is to make sure that the logic works on both FPGAs in different boards works concurrently without delay.
