SK_VA
7 years agoWhat timing constraints can be given for setting clock skew from FPGA input to PLL output between two similar boards in a system?
Hi, I have a 100 MHz clock fed to FPGA on board from an external board.Two similar boards are present in the system.Same 100Mhz clock is fed to both boards on the system.This 100MHz clock is input t...
KhaiChein_Y_Intel
7 years agoUser can set the skew on the data path only but not the clock path. Can you set the same location in both boards ?
