16 years agoWhat is wrong with this code?
LIBRARY altera;
USE altera.maxplus2.ALL; LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY test IS PORT ( a, b, c, gn : IN STD_LOGIC; d : IN STD_LOGIC_VECTOR(7 DOWNTO 0); y, wn : OUT STD_LOGIC ); END test; ARCHITECTURE a OF test IS BEGIN mux : a_74151b PORT MAP (c, b, a, d, gn, y, wn); END a; Warning: LMF mapping record a_74151b -> 74151b missing the "mux" port mapping(s) for node "mux" Error: Node instance "mux" instantiates undefined entity "a_74151b" Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 9 warnings Error: Quartus II Full Compilation was unsuccessful. 1 error, 9 warnings I use QuartusII 9.1 and port map a_74151 is ok. LIBRARY altera; USE altera.maxplus2.ALL; LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY test IS PORT ( a, b, c, gn : IN STD_LOGIC; d : IN STD_LOGIC_VECTOR(7 DOWNTO 0); y, wn : OUT STD_LOGIC ); END test; ARCHITECTURE a OF test IS BEGIN mux : a_74151 PORT MAP (c, b, a, d(7),d(6),d(5),d(4),d(3),d(2),d(1),d(0), gn, y, wn); END a;2 Replies
If you use VHDL'93 coding standard you do not need to include a package or declare the component.
Just google for "VHDL'93 instantiation style" - Altera_Forum
You need to include the component declaration for the a_741151b entity, either through including the package its declared in, or creating the component declaration in the architecture "a".
